nominal imp. of .7ohm and 1ohm coils, mixing ohm's
jonny101abc
SOCAL Stang-Man
2 questions
1. what is the nominal imp. of a 1ohm coil and a .7ohm coil?
2. what happens when you connect 2 diff imp. subs together in series-parallel?
example, say i connect 2 re mt's in series-parallel, and 1 is D1ohm and the other is D .7ohm, will one just get louder than the other, or will they not work?
Your nominal impedance is the just that. So say it's a "4ohm" driver, that's the nominal impedance. Then you have the Re for that, which would be in the ballpark of 3.something. For a "2ohm" it should be 1.something, etc...
If you wire two drivers in parallel and one has a lower Re, that one will draw more current. Generally not a good idea, but between a .7 and 1 ohm driver, I couldn't say how great the difference would be. You get the idea though.
Is that what you got for a reading with a DMM, .7 and 1 ohm respectively?
jonny101abc
SOCAL Stang-Man
jonny101abc
San Diego Punks!
ciaonzo
