No Zed group buy being organized yet?
  • Thread starter n2audio
  • Replies 0
  • Views 461
n2audio
OPTIDRIVEN
In an email from Zed Audio:
We apologize for the delay but are now pleased to announce that production of the new Zed amplifiers shall begin mid August.
Owing to the high demand for these amplifiers, we shall now accept pre-payment for your order as of the 25th July, 2009. In order for us to process your order, we do require your address so that the correct freight can be calculated.
The process shall work on a “first come first served” basis. Group buys are welcome and the applicable discounts are shown below. Payment may be made with a cheque, money order or Payal (Use ZEDAUDIO@AOL.COM as the recipient)
At this time we are only accepting orders by email. Orders will be netered into the system once payment has been made.
Yes there will be following production runs of these amplifiers PLUS some other new products (Including some tube gear).
KRONOS 250w/ch is $429
LEVIATHAN 150w x 6 is $599
California residents must add in the applicable sales tax OF 8.25%.
Final pictures shall only be available once production begins. These and other information shall be posted on our website.
Please feel free to contact me with any questions which you may have.
Here is a rough picture of Leviathan, the 6 channel. The picture does not show the plexi-glass top and the production boards will be black.
[picture attached]
Yours truly,
Stephen Mantz (for Zed Audio Corporation)
Retail Program
1) Purchase 1 amplifiers allows 0% off the MSRP
2) Purchase 2 amplifiers allows 2% off the MSRP
3) Purchase 3 amplifiers allows 3% off the MSRP
4) Purchase 4 amplifiers allows 4% off the MSRP
5) Purchase 5 amplifiers allows 5% off the MSRP
6) Purchase 6 amplifiers allows 7.5% off the MSRP
7) Purchase >10 amplifiers allows 10% off the MSRP
The two models we are introducing initially are KRONOS rated at 250w/ch 4 ohm or 500w/ch at 2 ohm. Its MSRP is $429.00. This amplifier shall be able to multi task. It will carry out the duties of a traditional 2 channel amp with High Pass, Low Pass and Band Pass functions. In addition it will do what traditional mono block sub amps do.
It will have loop through outputs for daisy chaining multiple amplifiers. The loop through sockets shall be the 3rd and 4th inputs for constant subwoofer fading.
LEVIATHAN is our 6 channel amplifier rated at 150w x 6 at 4 ohm or 300w x 6 at 2 ohm. Its MSRP is $599. The feature sets of this amplifier are so diverse that I shall post them on the web site in the next few days or you may request an email and we shall send this information.
The amplifiers shall be small and light and very efficient.
Sizes: KRONOS 272mm/10.7” L x 247mm/9.7” W x 55mm/2.1” H
LEVIATHAN 410mm/16.1” L x 247mm/9.7” W x 55mm/2.1” H
Some brief specifications
Specification ------------------------------- KRONOS ------------------- LEVIATHAN
Min spk impedance/ch ----------------------- 2 ohm ----------------------- 2 ohm
Frequency Response -------------------10Hz-25KHz -0.5dB ---------- 10Hz-25KHz -0.5dB
Input sensitivity -------------------------- 0.25v to 8.6v --------------- 0.25v to 8.6v
Input impedance ---------------------------- 37K ohm -------------------- 37K ohm
Noise below rated output ------------------- -101dB ----------------------- -98dB
Damping factor at 20Hz 4 ohm --------------- >80 -------------------------- >80
THD with 4 ohm -------------------------------- Less than 0.2% typically 0.03%
Low Pass crossover ------------------------46Hz-3.4KHz ----------------- 46Hz-3.4KHz
High Pass crossover ----------------------- 46Hz-3.4KHz ----------------- 46Hz-3.4KHz
Subsonic crossover ------------------------- 11Hz-48Hz ------------------ 11Hz-48Hz
Low Eq ----------------------------------- +12dB @40Hz ---------------- +12dB @40Hz
Low Pass crossover Ch’s1-4 ----------------- 80Hz-4KHz ------------------- 80Hz-4KHz
High Pass crossover ------------------------- 80Hz-4KHz ------------------- 80Hz-4KHz
Low Pass crossover Ch5+6 ------------------ 40Hz-240Hz ------------------ 40Hz-240Hz
High Pass crossover Ch 5+6 ----------------- 11Hz-48Hz ------------------- 11Hz-48Hz
Line out -------------------------------------- Yes --------------------------- No
I figured the big power a/b lovers would be all over the leviathan.
n2audio
OPTIDRIVEN
n2audio
Lawrence, KS
n2audio
