no power
San Diego 619
sup guys? i was testing out my new deck and it was working fine until i tried to mount it in and it just turned off and so did my car light, now theres no power when ever i press the on button. Can anyone help? I also tried puttin the stock deck back too and the power wouldnt work for that either.
in your fuse box.. what kind of car is it?
edit:
oh and you can use ur eyeball to check if its blown hahah.. no but really you can use a 12v battery tester on the fuse or you can yank it and see if its blown inside it..
someone with a camery should be able to tell you where its at... but in the meantime.. i grabbed this off some forum.. its for a 98 tho..
As for the fuse box, I believe that little "illegal" storage pocket pulls out, and you access the fuse panel behind that.
sounds like there is either a fuse problems or if it has come back on and then won't work it may be a simple loose connection. check behind the HU and make sure you ahve it wired correctly
the wireing is ok its just theres no power. my clock and the alarm thing that says your door's are open wont ring either.
Nvm i got it working it was my dome fuse under my hood //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
San Diego 619
San Diego 619
San Diego
San Diego 619
vegang
vegang
