no flippin idear wut crossover to get?
As that is a two channel amp, if you want to run both woofers and tweeters, you are probably going to need passive crossovers. Those are going to have to be some pretty hardcore drivers too, because at 1670 watts per channel and 8 drivers on each (if you're doing 4 mids and 4 tweets per side) you're running over 200W per driver.
Well, you could, but it would sound like crap. Music is recorded in two channels in order to create a 'soundstage', essentially the impression that certain sounds are being reproduced in certain places around the room (or car). Running all mids on one side and all tweeters on the other would give you monophonic sound, which means you wouldn't have a car stereo, you'd have a car mono. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif (Yes I know this is a perversion of terminology, I'm just joking around.)
You may not care, but if your mids are only playing say from the left channel, anything recorded on the right channel would not be reproduced and it wouldn't sound right.
Check this out.
http://en.wikipedia.org/wiki/Stereophonic_sound
Subwoofers on the other hand can run perfectly fine from one channel, because your ears cannot localize sounds of such a low frequency.
loudaccent
loudaccent
long island
orangecounty1
