No Dash Lights after install??
maco
Hey Guys, Nice site!!
I have a 1989 Chevy Caprice for my daughter's first car.
I bought it with stock radio and have installed a nice Sony am/fm/cdrw/mp3 player in it for her. She doesn't know yet!!
Any way to the problem, all works well but since I disconnected the factory wires the dash lights no longer work?? On anything??
I have checked all fuses and stuff and nothing seems out of place??
I was told by some one that when you take the factory radio out and not use the plug that will happen??
Now I know that the gray wire is for the dash dimmer and I am not using it. But does this make any sense to you?
Thanks for the help!!
Removing the factory radio won't normally affect the dash lights. The most likely cause is still a blown fuse; or you may have miswired the head unit to one of the illumination wires.
I have checked all fuses, and they are all good, I checked with a tester?
as for the wires, I used the two speaker plugs and the 2 power wires for battery and key, yellow and orange.
But there is a plug that came out of the radio that I did not use, it has a Gray, and Pink, I think there might be something else on there but I will have to look?
Gray is for Headlight dimmer wire and the Pink is for the Power Antenna.
Thanks I will retest all tomorrow and try to figure it out?
I will let you know what I come up with!!
I hate when a plan doesn't come toghter!!
I can almost guarantee you what the problem is.
The gray wire has to be hooked up for the dash lights to work. A fuse is probably also blown, the dash illumination fuse.
I can almost guarantee you what the problem is.The gray wire has to be hooked up for the dash lights to work. A fuse is probably also blown, the dash illumination fuse.
The gray wire remains unhooked on virtually every GM that I install a head unit into, and I've never had a problem with dash illumination on any of them.
maco
maco
Cape Cod, Ma.
jdawg
