No bass!!
jersyn82
Can someone tell me why my sub puts out hardly any bass at all when it's getting 1100-1300 watts @ 1 ohm? Need help!! I have steady voltage. Everyone told me to turn the bass off on here but no one can explain why I'm not getting any bass at all without it. Feels like it's rattling the car apart w it on, off its nothing!!
you mean your bass boost? Leave that **** off.
Only use head unit pre-out voltage strength via subwoofer level and overall head unit volume. Do not touch setting such as loudness, bass boost or bass frequencies in the EQ section on the head unit and do not touch bass boost on the amp. Its very dangerous to do so.
Because:
A sine wave form is pure and has all the information(basslines) in the song thats recorded into it. What bass boost does is trying to add extra bass, generally a 45hz frequency that was not there in the song in the first place this results in major distortion in the sine wave.
The sub is wired at 1 ohm. It's a sq hdc3 12. My volume goes to 40 but I can only go about 23 because of factory 6x9's. I have eq flat, bass boost off, loudness off, but my sub level is at zero because I thought that might hurt.
---------- Post added at 12:04 AM ---------- Previous post was at 12:03 AM ----------
It's 2 ohm dvc
It's 2 ohm dvc
Okay there's your problem buddy. Volume needs to be much higher, around 32 or so. Sub level needs to be maxed out. A sub level is nothing like a bass boost, it determines how strong the pre-out signal going to your amp is. Thats how you actually get the proper pre-out voltage coming from your head unit. Also the reason why your gain is too damn high.
So max out sub level.
Fk the factory 6x9s (disconnect em or something and raise up that head unit volume. Then reset your gains again.
Do you have a pioneer head unit? If so, your bass level can go to +6. Set it to that and then set your gain. If you have an alpine unit, leave your bass level at 0.
Regardless of headunit, leave your amp bass boost off.
Do you have a pioneer head unit? If so, your bass level can go to +6. Set it to that and then set your gain. If you have an alpine unit, leave your bass (SUB) level at 0.
that would really depend on what alpine head unit. Some test clean up to +10 or +15 on the sub level. The amp gain settings on those setups are ridiculously low.
Yeah true, I was just giving from my experience. Pioneer units I always set the sub level to +6 and then set my gain or else I get "no bass" and the same symptoms that the op described.
jersyn82
jersyn82
ohio
jersyn82
