No Bass after Imprint
gbryant
My deck is an Alpine IDA-x100. I added the Imprint processor(to increase line voltage and a few acoustical problems). When I initially installed it, the sound was pretty good... mainly the subs were much better controlled. Then... I ran the software and used the Mic.... no BASS!!! The rest sounds good , it corrected a harshness in the mids... but the subs barely run! HELP!!!
Thank you both for your replies. I will check my wiring for phase and ... no, I did not set the bass to 'minimum'. So... out to the garage...
yep, the imprint will cost you bass. i haven't been impressed with the imprint setup systems i've heard anyway, i much prefer a properly, manually setup up stereo.
It worked... after double checking phase... I set the sub amp to min, set up the Imprint, works great! Actually, my subs are much more controlled now and my system sounds real good... but, there's always ...better. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Thanks all.
gbryant
gbryant
kansas
gbryant
