nine.1 amp set up ASAP
headtrnr
hey guys i need to know what to put the following settings to run my sub here we go This is what the amp looks like from left to right first rca's
1.output / input / 2.LPF / 3. SUBSONIC / 4. BASSBOOST / 5. GAIN / 6. PHASE
1.A O / O / 2. 35hz- /3. 15hz- /4. 0db /5. min /6. 0
1.B O / O /2. 400hz /3. 50hz /4. 18db /5. max /6. 180
and on the far right it says SLAVE MASTER (it's a switch)
SLAVE has input above it output is above MASTER
bass and gain are pretty much to my ear but where do i set the rest
and where do i put the rca's into
Thanks hope its's not confussing:)
Input a/b is where the RCA's go (other input/ output is for strapping purposes), master/slave should be on master, subsonic filter at 25 hz or so since you are running ported at 32hz, xover I would use the one in the deck to set to your liking as it is easier to tune and turn the Nine.1's all the way up (400 hz) bass boost I would leave completely off as it can destroy a good sub, Phase at 0 unless you are wired out of phase then put it at 180.
headtrnr
headtrnr
Toronto
locotony
