NIB Taramp HD8000 2ohm version
JRCF71
Number of Channels: 01
Max. Output Power @ 13,8 VDC - 2 OHMS: 9595W RMS
Max. Output Power @ 13,8 VDC - 4 OHMS: 6305W RMS
Max. Output Power @ 13,8 VDC - 8 OHMS: 3646W RMS
Max. Output Power @ 12,6 VDC - 2 OHMS: 8000W RMS
Max. Output Power @ 12,6 VDC - 4 OHMS: 5256W RMS
Max. Output Power @ 12,6 VDC - 8 OHMS: 3040W RMS
Input Sensitivity: 250mV @ (-9,78 dBm)
Total Harmonic Distortion (THD): 0,5%
Signal Noise / Ratio: >90dB
Damping Factor: 400
Frequency Response: 5Hz to 15KHz
Crossover:
H.P.F (High Pass Filter): 5Hz to 50Hz(-12dB/Octave) Variable
L.P.F (Low Pass Filter): 50Hz to 15KHz(-12dB/Octave) Variable
Input Impedance: 18k OHMS
Protection System: Short into Output / Power Supply High / Low
Minimum Supply Voltage: 10,5VDC
Maximum Supply Voltage: 16VDC
Idle Consumption: 4,25Amp.
Musical Maximum Consumption @ 12,6VDC: 408 Amp.
Sinusoidal Signal Maximum Consumption (1KHz) @ 12,6VDC: 817 Amp.
Dimensions (WxHxD): 229 X 65 X 497mm
Weight: 6,11kg
$750 shipped.View attachment 26553748
JRCF71
JRCF71
Victorville, CA
JRCF71
NorthFramingham
    Jun 30, 2026
