NIB Dayton Audio IB385-8 15" Infinite Baffle Subwoofers
pickup1
Item(s) for Sale: Dayton Audio IB385-8 15" Infinite Baffle Subwoofers
Item(s) Description/Condition: new in box.. Dayton Audio IB385-8 15" Infinite Baffle Subwoofer 295-455
Overview
Build the ultimate home theater subwoofer by doing an infinite baffle installation! The Dayton Audio IB series subwoofers are designed to produce extremely low, clean, uncolored bass in infinite baffle situations
Highlights•Long Excursion Design
•Heavy Gauge Stamped Steel Frame
•Extremely Rigid Kevlar Impregnated Paper Cone
•Heavy Duty Treated Foam Surround
•Single 8 ohm Voice Coil on Kapton Former
•Bumped Back Plate
•Vented Pole Piece
The Dayton Audio IB series subwoofers are designed to produce extremely low, clean, uncolored bass in infinite baffle situations. Ideally, the subwoofers are situated between the listening room and an attic, basement, or garage using the floor, ceiling, or walls to separate the front and rear sound waves. Benefits of the infinite baffle approach include extreme low-frequency output, very clean and distortion-free sound, lack of large enclosures within the room, and amazingly loud bass with modest power amplifiers. Combining high sensitivity, good mechanical damping, and excellent excursion capabilities, the IB series subwoofers are the only drivers on the market designed specifically for infinite baffle situations. Made in the U.S.A. 5 year Limited Warranty.
PRODUCT SPECIFICATIONS
Power Handling (RMS) 350 Watts
Power Handling (max) 700 Watts
Impedance 8 ohms
Frequency Response 20 to 500 Hz
Sensitivity 88.2 dB 1W/1m
Voice Coil Diameter 2"
Magnet Weight 90 oz.
THIELE-SMALL PARAMETERS
Resonant Frequency (Fs) 21.5 Hz
DC Resistance (Re) 5.2 ohms
Voice Coil Inductance (Le) 3.08 mH
Mechanical Q (Qms) 8.92
Electromagnetic Q (Qes) 0.63
Total Q (Qts) 0.59
Compliance Equivalent Volume (Vas) 8.79 ft.³
Mechanical Compliance of Suspension (Cms) 0.26 mm/N
BL Product (BL) 15.46 Tm
Diaphragm Mass Inc. Airload (Mms) 207g
Maximum Linear Excursion (Xmax) 14.3 mm
Surface Area of Cone (Sd) 819.4 cm²
MATERIALS OF CONSTRUCTION
Cone Material Paper / Kevlar
Surround Material Foam
Voice Coil Wire Material Copper
Voice Coil Former Kapton® / Polyimide
Basket / Frame Material Steel Magnet Material Ferrite
MOUNTING INFORMATION
Overall Outside Diameter 15.16"
Baffle Cutout Diameter 13.77"
Depth 6.34"
Price: 170 shipped.for both..these are 129 each new...
pickup1
pickup1
Polk City Fl
pickup1
