mrbadwrench
So basically I purchased a set of eclipse sc6500 components, crossovers, and the set came with morel xtant 6 ohm tweeters.
The tweeters come off as harsh, and i guess this is because they are 6 ohms and the passive crossover is designed for 4 ohm tweeters that came with the set.
Basically, im wondering if I would be better off just buying a new set of 4ohm tweeters for around ~$100 or If i would be better off taking that same ~$100 to buy a small 2 channel amp for the rear fills and an electronic crossover and use the 4 channel I have now to actively crossover/power the front drivers/morel tweeters.
Hopefully that explanation/question makes sense.
