New Toys!!!
mr Tibbs
PG Xenon's!
600.1
100.4
Birthsheets
//content.invisioncic.com/y282845/emoticons/awesome.gif.4430a219d9aaaa6cadc75e9290979dfb.gif//content.invisioncic.com/y282845/emoticons/yes.gif.2d6d3882a589966b8145fbc57db57f33.gif//content.invisioncic.com/y282845/emoticons/veryexcited.gif.c26a15f316d23068607f36ddacd7a7ab.gif
what model are those? do i see they are overrated or am i wrong?
600.1 rated at 600w@1-4 ohms, actual = 834@1-4!!//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
100.4 rated at 100x4@1-4 ohms, actual = around 140x4@1-4 ohms!!//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
nice amps. i have a old school pg amp and i love it. what are they gonna power?
The 600.1 will power a 12" RE SE in a sealed box(for now) and the 100.4 will power a front active stage with 6.5" Phaze mids and LPG 25NFA tweets.//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
mine blew in 5 days.....I wish u luck
It's most likely you had the first batch (the bad batch). The new batch should perform well without a problem.
Hmmm, I don't remember what the graphs represents. Its obviously power vs. something.
I think its voltage vs. power
If we assume x vs. y
x-being THD
y-being power output
I believe the graph represents THD vs. Power. You can see on the graph that the x values are small, and the y values are rather large. So I would assume it is THD vs. Power.
You can see right after the ~830 w rms the graph the slope increases substantially, that means there is so much THD that the output is not going to be very clean, I believe. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I like PG graph, a graph would best represent an amplifier power output, I just wish they would have another graph showing frequency vs. power.
If we assume x vs. y x-being THD
Yup, you are right... just looked at my 1200.1 birthsheet.
mr Tibbs
mr Tibbs
Utah
bibby
Mike Mccabe
