Ok, so if I have 2 L7 12 inch Subwoofers, Is It Going to push good if I get 1 2400 Watt Amp that has A RMS of 1400, will i be able to hook both of the speakers up to it???? Will that be enough power for them? And Its A Class D Amp
Ok, so if I have 2 L7 12 inch Subwoofers, Is It Going to push good if I get 1 2400 Watt Amp that has A RMS of 1400, will i be able to hook both of the speakers up to them???? Will that be enough power for them?
Well that depends on a number of things. What impedence will the amp handle? What impedence are the subs? If 4omh subs you can wire them to either 4omhs or 1omh. If both are 2omhs then you can wire them both to 2omhs. Most decent amps will handle a 2 omh load, but always check the manufacture specs to make sure. Almost every amp will handle 4 omh loads. 1 omh stable amps are expensive, but wiring to the lowest impedence that both your amp and subs will handle will yeild the most output from your amp. But yes as the RMS for L7s is 750W, 1400w will drive two just fine. That is, considering that its really 1400w. Diffrent amp producers use diffrent rating tests and yeild wildly varying results, making ratings hard to compare. What amp are you looking at?
The Speaker Says Dual 4 Ohm Independence and The Amp Is 1 Ohm Stable here are links and tell me what you think and give me advice on an amp kit for them.
