New Precision power amps any good????
Yeah that's what I was thinking... Here's a cut and paste from the amp I was looking at.
Features:
Sequenced Delays Eliminate Residual Power-Up/Power-Down Pops
Differential RCA Inputs Isolate 12V/Audio to Ground, Eliminating Ground Loops and Noise
Full Signal Path Low Noise/Distortion Circuitry Topology
Optimal Component Layout for Minimal Distortion Induction & Signal Separation
Triple Darlington Audio Output Stages
Differential Drives Divide Pre-Amp & Power-Amp Stages, Eliminating Ground Looping
Full Differential Feedback Surrounding Power-Amp Stages directly from Speaker Terminals resulting in Uncolored Sound Reproduction and Elimination of Ground Loops
Output Stage Bias Individually Sequenced, Optimizing Sound Quality
Stout 2 Oz. Copper Traces Effortlessly Transfer High Volume Internal Current
Close Tolerance Signal Path Components - 1% Resistors & 5% Capacitors
Parametric Bass Equalizer - Proprietary Bass Equalization
Continuously Variable 41 Position Detent Crossovers
Variable high-pass filter (15-4,000 Hz, 12 dB/octave)
Variable low-pass filter (50-4,000 Hz, 12 dB/octave)
Damping Factor (100Hz @ 4 Ohms): >2000
Frequency Response: 15-50,000 Hz
Signal-to-Noise Ratio: 102dB
THD (Total Harmonic Distortion): 0.02%
Dimensions: 13-3/4"L x 10"W x 2-5/16"H
Specification:
Amplifier Class AB
Number of Channels 4
RMS Power (4 ohms) 70 watts x 4 channels
RMS Power (2 ohms) 100 watts x 4 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 200 watts x 2 channels
Total RMS Power Output 400 watts
Maximum Input Gauge Size 4
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.02%
Built-in Crossover Low-pass (LP), High-pass (HP)
High-Pass Crossover Frequency
15 - 4,000 Hz
Low-Pass Crossover Frequency 50 - 4,000 Hz
Signal-to-Noise Ratio 102 dB
Channel Separation 74 dB
Bass Boost 0 - 12 dB
Bass/Gain Remote Yes
Fuse Rating 60A x 1
Well I bought the Precision Power PC400.4
Guess we'll see how it sounds etc..
I see they are for sale on ebay for 279.99 so I feel better about the price I got mine for, I only paid 110.00 for one bnib.
deez283
deez283
Aberdeen, WA
SPLaudio
