12 to 13 ft of 4 ga is fine for the Nine.1 alone, but I wouldn't recommend running the comp amp off that same run of 4 ga. As was stated above, the Nine.1 is a real monster running @ 1 ohm, and will draw a lot of current. If you're running it @ 1 ohm, I'd suggest a minimum fuse rating of 100 amps, and 125 would be better. Maybe look into a 150 amp circuit breaker or ANL fuse setup for both amps, and upgrade main power cable to 0 gauge, then split if off at the amps to dual 4 ga with a fused distribution block.
