new memphis moofer
InhumanAcura
1/3ofTEAM PwNAGE..*****es
pretty sweet..motor looks similar to some un-released subs..
http://www.memphiscaraudio.com/products/details.asp?cat=&id=158&p=2
Impressive... Good for them.
Shit, a 4 layer 4" coil... there's gotta be some wicked inductance there. Even if it's copper...
Oooh, 10" slugs.
Interesing, I'm gonna have to put a bug in someones ear about this... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
-Nick
Oooh, 10" slugs.
-Nick
Well, the coil being copper or aluminum has no bearing on the Le. If they are the same winding length, width, and wire gauge, they'll have the same Le in that motor.
Given a 4" diameter 2" long 4 layer VC, I'd wager the Le is around 8mH or so, possibly higher if they used really small gauge wire. Looks like probably 24AWG or so though.
check this out-
Code:
Nominal Impedance Znom ohms 4 (1+1+1+1)
DC Resistance (per coil) DCR ohms .985
Resonant Frequency Fs hz 32.56
Qms - 4.985
Qes - 0.360
Qts - 0.336
Xmax (linear) one-way - .625”in
Xmax (mechanical) - 1.25”in
Sensitivity @ 2.83volts - 92.75db
Sd - 0.08sq. m
Vas - 2.396cubic foot
Mms - 319.81grams
Cms - 74.66um/N
Voice Coil Diameter - 4.0"in
Voice Coil Length - 2”in
Voice Coil Layers - 4
Voice Coil Type - Quad
Continuous Power - 4000watts
Peak Power - 8000watts
Magnet OD - 10”in
Magnet Thickness - 2”in
Magnet Weight - 400oz
Frame OD w/gasket - 15.57”in
Mounting Hole - 14.25”in
Mounting Depth - 8.5”in
Speaker Weight - 53lbs
Driver Displacement - 0.342cubic foot
It'd be nice if they made an 18" with some decent coil options...
Hopefully it is an effective field replacable woofer....we need more of those //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
they are indeed extremely easy to replace in the field..
also..i'll take the new mojo amp over just about anything....save a crown, or 4kw..big power..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
Eh...those QCA type assemblies (Like the TI Pro) have GOT to be MAD expensive. I mean, MT's aren't all that hard to re-cone at all...some people are just lazy i guess //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
NG
NG
IIRC, they are about 1/3rd to 1/2 the cost of the original woofer...and u can change size as well....a 10" will fit on the 15" motor..of the same series..m3 or m3mojo or this new mojo that is pictured..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
InhumanAcura
InhumanAcura
South Florida
bigbassman
