MB Quart QSD 216
These are brand new, never been used or hooked up.
Still in the original box, without the slipcover on it however.
The MB Quart QSD 216 car speaker is a two-way vehicle speaker ready to produce high and mid-range sounds via the tweeter and mid-range speaker. The MB Quart car speaker can supply up to 80 watts of power. As a non-powered speaker, the two-way car speaker relies on an external power source to create the high and mid-range sounds intended to come from this unit. The MB Quart car speaker has a 4-Ohm, dual-coil impedance and a sensitivity of 85.5 dB. The speaker is made with a polypropylene woofer and titanium tweeter. The unit is a non-enclosed speaker, meaning that it does not come preset in a speaker box. It must be set in a box as a standalone speaker or as part of a speaker set. The MB Quart car speaker uses a built-in passive crossover system. The MB Quart QSD 216 car speaker requires a minimum frequency response of 32 Hz and a maximum frequency response of 32 kHz. The two-way car speaker is part of the Q-line of car audio products from MB Quart.
$475
$15
MB Quart QSD 216
$475
$15
