New here
welcome man..hows it going?? hope to learn from you as well..what are you trying to accomplish,and with an amp, or head unit(hu)to power the tweets? or??what you got going on? ill try help much as i can:santa:
I was trying to avoid using an amp to power the tweeters and maybe replace the tweeters in the dash or run them off of the door speakers?
you can do either??just make sure + to+/- to -,and do use the xover they come with,,if your door speakers are amped,and normally @4ohm,by adding the tweeter will bring it to a 2ohm load,in which if just the two on that one ch,and both are 4ohm speakers,then that amp should drop to 2ohms on that ch,in which majority of the amps are stable/fine at,just make your adjustments as needed/gains to your liking
robert_powell
robert_powell
Whiteville, North Carolina
robert_powell
