New head unit works fine on the bench, not in my car.
I installed a Sony head unit a few years ago and it worked fine up until a month ago. All of the sudden it became unresponsive and would not function properly. Aside from being able to turn the volume up and down I could do nothing else. I pulled the unit and bench tested it and it was still unresponsive. I ordered a new Pioneer head unit from eBay wired it in and it did not function properly. It played fine but I could not pull up the menu to go into the system settings, control my iPod, etc. The remote would not work either. I sent it back and got a new one. Same problem...
I pulled the unit out and bench tested it and it works fine on the bench, not in my car. This tells me the problem is my car/wiring and not the head unit. I double checked my wiring and everything is fine. I also tested the ground when it screws to the chassis and it is fine as well as the additional chassis ground.
Any ideas as to what to check next? I am hoping that someone can steer me in the right direction.
Thanks in advance for the help!
How did you check the wiring? Multimeter? Test light? Did you use a factory to aftermarket adapter? Definitely a harness issue.
I checked the grounds with a power probe and used a Scosche wiring harness.
Try bypassing the harness for your power and acc. Run the hot to the battery and the acc to a switched (power with the key on) source and see if it powers up correctly. If that works, you can leave it that way.
Thanks for the input. I will give that a try.
Solidsnake
Solidsnake
United States
Solidsnake
