new experiment
The amp will not put out anywhere near 1000w... Never look at peak ratings, they are just advertising techniques and are rarely based off actual specs. Expect around 700w or so from that amp, I used to have one and gave it to my brother (just fried it the other day actually.) As far as quality, I would say they are some-what reliable, but I wouldnt run them. I had the 8002T as well, and both often ended up in protection mode for no apparent reasoning. But for under $150, they arent as bad as most make them out to be.
But if it all sounds good to you, that is all that matters...
Although I dont know how you can relate SQ to those Audiobahn 4x6's....
[/url],hers my new experiemnt as learn to buld boxes, AW1500N dual 4ohm voice coil 800rms 1600peak running off an A800t mono amp at 2ohms 800rms 1600peak, someone is designing abox plan that i will attempt to build, how do you think it will sound????
when tuning a sub is the tunung frequency as low as the sub will play?
well the odds are against you, i would say 10 out of 10 installs it would sound like *** since its audiobahn
Which is nothing special...
at all.
haha but really, you should have asked around first, anyone on here could have gotten you something way better in quality and for pretty cheap. you pay for what you get man, 89 bucks for a sub is just as bad as the sonys at wallyworld......
cooper1513
cooper1513
ny
NhustlaR
