New Arc Mini amps
Are they any good?
It depends on what you're looking for. I have one, because it fits into the glovebox and weighs almost nothing. It has more than enough power for my needs, which admittedly aren't geared toward SPL. YMMV
That's pretty much my needs as well. Want something, light, small and I don't care about spl either. Think I may try one or two out. Are there any other competing models from other companies that are comparable in size and weight?
IIRC, Elf Audio sells a model based on a very similar design, as does another firm whose name I can't recall ATM. Both are as small or slightly smaller than the ARC. Before I bought the MINI last summer, I considered the other options and realized that I was either dealing with vaporware or a more expensive product whose guts looked exactly like the ARC. Things may be different now. FWIW, mine is driving Boston Pro60s.
They are quite expensive. Sony has a mini amp as well. I am sure it does just rated power (50x4)..and it can be had for less than half of the arc.
I am still in between the two. I may check out PA's version for a more middle of the road approach.
NE14MX
Finish the Drill
NE14MX
Georgia
audiolife
