nevermind
For instance, 2002 Ford Mustang:
12volts yellow & lt. green/purple + ignition harness
Starter white/pink + ignition harness
Ignition red/lt. green + ignition harness
Power Lock lt. green + 20 pin plug, pin 20 at GEM
Notes: The GEM (Generic Electronic Module) is located above the driver kick panel.
Power Unlock purple + 20 pin plug, pin 18 at GEM
Lock Motor red/white 5wi 20 pin plug, pin 9 at GEM
Unlock Motor red/orange 5wi 20 pin plug, pin 7 at GEM
Disarm Defeat pink/orange 5wi 20 pin plug, pin 8 at GEM
Parking Lights+ brown + 26 pin plug, pin 7 at GEM
Parking Lights- white/black - 26 pin plug, pin 11 at GEM
Hazards same as turn signals
Turn Signal(L) lt grn/wht(F), lt grn/org® + steering column
Turn Signal® wht/lt blu(F), org/lt blu® + steering column
Door Trigger yel/black (L), gray/red ® - 20P plg, pin 13 & 5 at GEM
Notes: Use yellow/black for the driver door trigger and gray/red for the passenger door. Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
Dome Supervision black/white + 20 pin plug, pin 3 at GEM
Trunk/Hatch Pin brown/white - 12 pin plug, pin 3 at GEM
The hatch pin needs to be diode isolated from the GEM module. Refer to DirectFax document 1076 for wiring information.
Hood Pin N/A
Trunk/Hatch Release pink/lt. green - 26 pin plug, pin 25 at GEM
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm dk. green/purple - 20 pin plug, pin 16 at GEM
Disarm No Unlock see factory alarm disarm
Tachometer NOT red or white/lt. blue ac ignition coil or coil pack
Horn Trigger yellow/lt. green - 26 pin plug, pin 12 at GEM
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
PATS
Part #: 555FW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
or stereo:
Radio 12v purple/lt. blue + radio harness
Radio Ground black/lt. green and black - radio harness
Radio Ignition black/pink + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- org/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- wht/lt. grn - green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Yes Type:
PATS
eatank
eatank
shingle springs,ca
eatank
