If by material type, then yes that is right.Glad you didn't quote me on that.
Subs need higher grade neo because neo will lose its strength when exposed to high heat levels. The higher the grade, the hotter it needs to be for it to lose it's strength.
Yeah, imagine putting 20+ 6"x4"x1" N52 blocks on a single plate, same polarity. That's where fingers get crushed. On the second magnet, it will want to flip when you get it on there, if it does, it will take you fingers with it, wedging it to the plate or the other magnet.More then likely. Putting the blocks that close together will definitely cause them to attract. And the plate will for sure not cooperate.
Yes you do. If you know, it kind of entitles you. I mean really, for the sake of comprehension.Yes your correct. But the grade is a good starting point, higher flux will also in terms relate to higher energy product. No one really sits with a spec chart of neo in front of them. So they give the grades for us to go off of.
And //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif you don't have to be so anally correct.
What inductance thing are you talking about? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifYou do around here. Especially when you get dorks spreading FUD saying lower grade magnets make the driver crappy compared to ones of higher grade. Once those types of statements have been burned in people's brains, it is difficult to correct it.
Kind of like the whole inductance thing with subwoofers...
Sorry, it has been a long day for me. I'm confident if you look around here or a couple of other forums you will see threads dedicated to the whole high vs. low inductance in subwoofer drivers.What inductance thing are you talking about? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have and it is retarded.Ive never really seen anyone make a comment saying "x sub uses n40 don't get it"
Neo by all means is superior then ferrite. Only if it weren't so dam expensive, and hard to produce. I also imagine a woofer company having to upgrade alot of equpt in order to produce a neo based sub.
Well, on the super technical side, higher inductance will create a stronger magnetic field for a given current. I'm not saying one is better than the other, but that is a fact. It's BL and inductance if I were to guess. There are really too many variables to really grade a sub.Sorry, it has been a long day for me. I'm confident if you look around here or a couple of other forums you will see threads dedicated to the whole high vs. low inductance in subwoofer drivers.
I certainly did not mean to derail this thread..
