Neighbor gave me some peel n seal.
It was worth every penny you paid //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
P&S does have a tendency to come off, in some cases...make sure you use a heat gun when applying it.
Using as many layers as will fit is never a bad idea.
And make sure where ever your applying it is as clean as humanly possible //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
A Street Division competitor may use 2 layers of damping material on the inside sheet metal of his roof. However, the competitor may not use 2 layers of damping material on his roof and another 2 layers on the backside of his fiberboard headliner because this would result in a total of 4 layers of damping material in this location.
A Street Division competitor may use 1 layer of damping material on the inside sheet metal of his door and another layer of damping material on the backside of his door panel because 2 layers of damping material are allowed at any given location. On the other hand, the competitor may not use 2 layers of damping material on the inside sheet metal of the door and another 2 layers of damping material on the backside of the door panel because this would result in a total of 4 layers in the door location which is prohibited.
Just think about that for if you ever plan on competing in DBdrag.
Well, I deadened one of the doors. I only put on one layer because I have something to do in a few.
I dont think the pics really need to be up here, because I dont think I did to good of a job. But since youre all such nice people.
Here they are
Dont forget. I am going over it with another layer. lol
Don't forget the outer door skin...
I don't know how serious you're going to be about this, but check out the sticky in the Speakers section; "Proper Deadening & You"...contains good info about building baffles and using clay to decouple the speakers from the door, and filling up those big holes that are costing you midbass response.
I sealed up my doors with Lexan, used MDF and modelling clay around my speakers, and the midbass response improved dramatically.
I am going to do alot more to the doors. Then I will need some more material because I am going to run out on the other door.
I would have covered alot better if I didnt have to go somewhere.
supraman1379
Lifted 03 HEMI
supraman1379
Ocala, Fl
Sleeklsc
