Need Some help with enclosure!!!
808skindiver
da 808 ulua slayer
i am building my enclosure today. it is for a 15 audiopulse axis sub. the enclosure is going to be 28" x 19" x 19" with around 3.5 cubes tuned to 32 hz. my main question is what size should i make the port or what square port displacement should i build exactly? any help greatly appreciated. thanks
i am using the re box calculator. i just wasted to know what the difference would be if i ran a 3" port compared to a 3.25" port. it only bumps up the square port size about 4 square inches. thanks
17x20x24 is 3.74 cubes then after sub and port displacment it will be around 3.5 cubes
Your only allowing .24 ft^3 for sub and port displacement?
The sub is probably almost .2 ft^3 by it's self and a slot port tuned to 32hz with enough port area will probably be close to 1 ft^3 if not more.
808skindiver
da 808 ulua slayer
808skindiver
808 state
808skindiver
