Need some calculation help
  • 1
Randy Savage
New York
ok, my box is going to be 2 separate chambers, each with an internal volume of 2.65 after sub displacement. I want to tune it to 36 Hz, and preferably 3" PVC ports, how long shall they be? Jmac I know you can help me out with this one...
Everything in my sig...and thats the vol. after sub disp. but before port, i dont know how much port disp is, im guessing around .075 cu ft?? I dont know, I'm truly lost right now
Ok, right now im lookin at like 20H x 34 W x 18 D, volume of 5.74 before any displacements, 5.22 after sub displacement, what dimensions should I make the slot if I have one common chamber?
THANK YOU THANK YOU THANK YOU THANK YOU JMAC //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
127
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
104
445
343
750
Randy Savage
Randy Savage
New York
Randy Savage
    May 12, 2024
Brendon Jenness
    May 11, 2024
