need help please read
Gamedemon
AudioNewb
ok i have a kicker comp 10 300watt 4ohm with a 350 watt infinity mono amp and
the parents bought me 2 walmart sony xplod 10s 1100 watts (i think maybe 4 ohm) each and i think they may have the bump i need but will this amp push 1 sub to its limit or am i looking at the wrong amp? i am gonna buy 2 if they will push the subs 2 the limit but if not i need a someone to suggest another amp
heres the amps specs
2005 Sony Xplod XM-SD51X Monoblock 1100W Amplifier
Sony Xplod Competition 1 Channel 1100 Watt Amplifier
Continuous Power Output @ 4 Ohms: 250 Watts(rms) x 1
Continuous Power Output @ 2 Ohms: 500 Watts(rms) x 1
Maximum Power Output Of 1100 Watts
Built In Elelctronic Low Pass Crossover
Crossover Frequency Variable From 50 Hz To 300 Hz
Integrated Bass Enhancement Circuitry
Bass Boost Center Frequency Set @ 40 Hz
Bass Boost Variable From 0 To +10 dB
Built In Sub Sonic Filter
Sub Sonic Filter Frequency Set @ 15 Hz
MOSFET Output Stages
Pass Thru Pre-Amp Outputs
Low Profile Design
Gold Plated Connections
Remote Variable Subwoofer Level Control
Also Accepts Speaker Level Inputs
okay i had a really hard time figuring out what you are asking. are you wondering whether you should get 2 of those amps to run your 2 sony subs? nobody likes sony on this board so expect to hear a lot of "take them back" or even "throw the xplods away" because sony car audio is not very good. please explain this more clearly and you'll get more feedback
ok here we go im sorry noone likes sony its the only cheap arse thing i could get my father to get me for xmas (parents are divorced so dads not the best then again he never was lol) i was asking if 1 of those amps would power 1 sub and push the 1 sub to the Very max of its breaking point? or do i need a bigger amp
Gamedemon
AudioNewb
Gamedemon
Texas
Gamedemon
