need help building box today
Aeros are easier to calculate (more accurately anyway), easier to change and work MUCH better if you have space constraints, but can fit a long straight pipe, which would be easy in your case. Run the sub facing up like you have it, port running across the vehicle. If you can cut a circle to fit a sub, you can cut a circle to fit an aero lol.
do not underestimate the circle! lol
edit: but op i got your message and tom. i will send you two designs.... one with a slot port and one with aeros so you can choose what you want to do.
3 cubes@32hz 3" wide port
will it work?
thats if i can fit 16.5 high box
port is 3" wide, 15" high, length is about 32 long
re calculator says its 3 cubes @32 and thats after i subtract sub displacement
bro listen to tempest, ram, and dman. these guys know there shit. not just the numbers. but how actually how the sound is reproduced and done so most efficiently. get one of them to work with you. you'll be happy in the end.
yup... thats why im here... making a thread... for help...
best i can come up with is 3.18 cubes@33hz with 40in^2 of port area. after sub displacement ill be right at 3 cubes, which is what DC suggests.
i know its a little small but thats the best i can do with the area i have unless i just use the whole crew cab haha.
Cruzer
Cruzer
smyrna, tn
Cruzer
