Need a Lil advice?
  • 4
Jisthaname
I'm attempting to build it all in one box. With a power supply from my computer a car amp ,card deck ,and Subs tweeters and mid-range. Maybe a USB power source and a led light kit. I plan on using a psu like on my home unit. What would be a good type of material. Fiberglass. Or mfd. Ect. Most of the rest I can do just need to know if I build it from mdf or whatever. Will fiberglass wrap help.
142
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
106
447
345
753
Jisthaname
Jisthaname
Tulsa ok
audiobaun
    May 16, 2024
    May 16, 2024
