MythBusters: CA.com - Episode 1
I think a better thing would be to test SPl cap vs. no cap.
I haven't seen many threads saying "I blew my subs my underpowering them"
Loyd did this test on CSO a while back, unhooked one of the small batcaps in Jason Maloney's jeep and gained .3-.4 db iirc. Also in his jeep it was louder with the seat folded up. Too bad cso crashed or i would find the post.
Also Loctite Wood Glue > titebond II, i tested it lol
loctite wood glue comes from wal mart its caled wood worx iirc
Ill check that out, will be building another box here soon. Why do you say its better?
without letting the glue cure fully ( about 2 hours cure time ) the loctite held a joint with more weight on it before failing, ( after a full cure it doesnt really matter as the wood breaks before both fail, but i hate waiting lol )
also the loctite is slightly cheaper, the end of the bottle has a neat screw cap that works much cleaner and nicer than the titebond
also the loctite is a bit thicker so it doesnt run nearly as bad as the titebond.
you know although this is a really old thread (at least i didnt bump it) i figured i would tell you this:
while i was googleing how to replace tinsel leads, i came up on the RF forum where someone told a guy that with the T1's its a common problem to break tinsel leads by underpowering the woofer //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i mean wtf? how do you break a tinsel leads if the drivers isnt even moving or barley moving due to being underpowered //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
ngsm13
