I've said it before, and I'll say it again, number one **** disturber...I know!:thumbsup
What does that have to do with under-powering a sub?i'm going to have to disagree with the "underpowering of a speaker/subwoofer" being a mythif you overpower an amp to clipping, and that max power still is not enough for the sub, then wouldn't the clipped signal being sent to the speaker damage it?
You just contradicted yourself. The earlier post was on UNDERPOWERING a sub, you just stated overpowering a sub. Yes, you can damage a sub by overpowering it, but not by underpowering it.i'm going to have to disagree with the "underpowering of a speaker/subwoofer" being a mythif you overpower an amp to clipping, and that max power still is not enough for the sub, then wouldn't the clipped signal being sent to the speaker damage it?
i thought i explained it pretty wellWhat does that have to do with under-powering a sub?
~ Kyle ~
Yes, if the signal you are sending it is clipping, you will damage the speaker, but if you watch your gains, and don't clip the signal, even if you are giving a sub rated at 1500 rms, about 1000 watts, or even, 750 watts, you will not damage it...i thought i explained it pretty well
if you have a sub rated at 1500 watts rms, and you have an amp powering it that puts out 1000 watts max, and you're sending the max amount of wattage to the sub, and the signal you're sending it is clipped constantly, won't that damage the sub over time?
so, in certain scenarios like that one, underpowering can indeed damage a speakerYes, if the signal you are sending it is clipping, you will damage the speaker, but if you watch your gains, and don't clip the signal, even if you are giving a sub rated at 1500 rms, about 1000 watts, or even, 750 watts, you will not damage it...
And no, you did not explain it well at all...
~ Kyle ~
I believe you are correct, I knew this guy at my old high school, who had a 100 watt pyramid amp, running hiw mtx road thunders, rated at 150+ rms each, 50 watts a piece, and he had those suckers runing for a good two years, without anything going wrong... Shiatty amp, and those subs were still in good shape...Sorry but I believe the whole underpowering thing is![]()
MYTH
In your own muddled way, with the help of myself, and tommy, your point was made, yes...so, in certain scenarios like that one, underpowering can indeed damage a speakerthats the point i was trying to get across
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifIn your own muddled way, with the help of myself, and tommy, your point was made, yes...
~ Kyle ~
Leave it to you...Lets disturb the **** outta this one!![]()
Myth or Fact: Jensen makes quality products!
Exactly, they were arguing this on CAF.com one time. It basically amounted to you can clip the hell out of an amp if the driver used could take 3x the RMS power of the amp (they might have only been talking about subs though, can't remember exactly). This is the ever so popular "destortion kills a speaker" myth.Even a clipped signal will rarely Damage a speaker to the point of it being blown.. The only way to blow a speaker is with too much power. A clipped signal can destroy it...but generally it will just sound very bad.
MYTH: you are wiseFACT: JL Audio Amps are considered the best BECAUSE no mather what ohm you run them at, the watt output is the SAME. I have yet to find another Amp that has only 1 given out put for different ohms.
FACT: This is the main reason why JL is so freakin EXPENSIVE..... I still love them!
