yup, i hear ya. my amps both have clip indicators. makes it fool proof.I'm lucky my eq lets me know when I get a clipping signal so I dont fock my shit up.
sounds like blown or burnt up crossovers, which also happens from clipping. at least the crossovers protected the tweeters.
did you disconnect a tweeter and try to get a reading on a tweeter by itself? should read just under 4ohms.
check the tweeters themselves with a dmm and see what resistance they read before doing anything. if they are fine and you just need crossovers i have a set of the rsd crossovers not being used.Hmm maybe I should try that..
So.. New crossovers.. Can I buy them alone? anywhere.. Doesn't have to be PG ones, just any decent one will do.
That would be great if I could buy those off of you //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifcheck the tweeters themselves with a dmm and see what resistance they read before doing anything. if they are fine and you just need crossovers i have a set of the rsd crossovers not being used.
what are you talking about?Man this sucks! Good thing I only have 50rms at 4ohms x4 and 75rms x4 at 2ohms at hand.
I usually only turn my amp up half way, if that.
That I won't have a shit ton of power going to them.what are you talking about?
if anything this thread has talked about him not having enough power. you are less likely to drive the amp into clipping if it is a bigger amp. i am running active with 200 watts rms per mid and 100 watts rms per tweeter. so it's not a matter of to much power. it's a matter of to little clean power. this set sounds ridiculous off a ton of power, believe me. and i have never heard any signs of them being over driven.That I won't have a shit ton of power going to them.
Nor do I turn up my amps to high to send a clipped signal.
I was actually thinking of getting another amp to get more watts to my Rsd's, but after reading these bad reviews, I am thinking of keeping my amp I have now and just see how I like it. If anything, I can run the rears of HU power and then bridge my amp to send out 150rms to each side.
Isn't that what you are running with no problems? I do believe you are running active though, which you have more control with your settings through the deck, correct? You also have a 880 like I do. I still get lost just running passive, lol!
