My System
MJ23FE
My signature has all the info you really need. I installed everything in the trunk myself.
Head unit, Components, Coaxials, original running of the wire was done by a shop.
Before and After pics.
I still need to zip-tie and organize all the wires. I also need to put new spade terminals on the right channel speaker wires connecting to the Tantrum 500.2, i took them off trying to get rid of noise than really came from a loose rca. My back was killing me ater sitting indian style in the trunk with my back/head bent under the rear deck for 2 hours straight at a 45° angle. I did not put the side rear panels back on because i would have to cut them so that they didn't get in the way of the amps,distroblocks, capacitor. I also need to find a way to keep my box from flying around in my trunk without the use of screws and brass L brackets. Maybe rubber sticky things? Anyone got any ideas? I plan on switching it out anyway and dropping a single Elemental Design 12A.22 in a sealed 1.2cu.ft. enclosure, which would later switch out in place of a ported enclosure built to eD specs.
Regardless, this setup i currently have sounds amazing, and its everything i could ever ask for.
What do you guys think?
-Jalal
what?? a shop ran those wires?? i would have taken that **** back and told them to redo it. it looks good if just an average guy did it, but theyre soposed to be professionals. i woulda taken that back man.
I mean that they ran them to the back of the car... like from the battery and the headunit to the trunk. I re-wired everything in the trunk as it looks now, a shop didnt do that.
This is a picture of all the shop ever did.
I added another amp and installed a cap so i had to change things alittle.
-Jalal
MJ23FE
MJ23FE
Bergen County, NJ
Bavarian3
slater
    Oct 4, 2025
    Oct 4, 2025
