My Stetsom 7kd Test results....
Korn4Life
SUB LOVE
So i just clamped my Stetsom amp and here is what im getting out of it... I am running a pair of 12" DD 9512g's Dual 2ohms...Im running the amp @ 2ohms... I have a Stock 105 amp alt a stock battery up front and 3 stinger spv70 Batteries in the back...
First test
50 Hz tone
14.82 amps
105.5 Volts
= 1563 watts
Second test
55 Hz Tone
20.44 Amps
104.9 Volts
= 2144 watts
Third Test
60 Hz Tone
22.2 Amps
96.5 Volts
= 2142 watts.
Also the biggest drop i had in voltage was 14 volts dropping to 13.18 volts.
So as you can see my box rise is pretty high and my question is can I or should I run this amp at .5ohms and test again... Also could I run daily at that load... The amp is rated for 1ohm... Thanks for the Help
I think the DD 9500's will love to see the power that amp can put out at .5
Depending on your box rise (DD's tend to rise pretty high from what I remember?) you may be around 1ohm, possibly even over it, so it may not even be a problem. Wire them down and see what it rises to in my opinion. That amp is so much more capable then 2kw at 13.2V from what I've read.
Wire it down to 0.5 and test it. I clamped 7300+ 0.86 ohms from one of mine with 4 group 31 batteries.
Dont run it below 1 ohm for daily, it is very unstable on music on less than 1 ohm. I dont use mine for music for that reason.
Nice results bro. Now drop that bish to .5 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Go to .5 ohm the subs to see what the true DC load is and then retest.
Sweep the freq from 30 to 100, watch both meters to see if you even get close to .5, I would bet you never see more amps than volts.
You do not have to do it with the volume up, just do it on level 5.
Says who?
The loudest vehicle on earth uses Stetsom......that should be enough right there, at least not to put them down i would think
The fact that dante is loud, has absolutely nothing to do with his amps.
You could put any of the top amps out, maxxsonics, ia, sundown, etc and still be close
Yehh....but it has STETSOM amps.......not the others
Why would anyone say "Its not all its cranked up to be".....if you say it can be swapped out with the TOP amps and be close
Thats all im saying, not that its the GREATEST amp, but i wouldnt say that statement putting it down
Yeh his car is 95% in his build, hes proven that with doing 70s with 1 2510 and a 2k6
u my friend are an idiot
Yehhh.....good argument there buddy
Korn4Life
SUB LOVE
Korn4Life
PA
Unholysavage
