my new buss bars
jeepintn
well, i know the first thing everyone is gonna say, shouldve used copper, and i know that, but with copper as expensive as it is right now, this aluminum/copper alloy will have to do. i bought a 48" bar from pierce metals online that is .5" thick and 1" wide. i then cut it into 6" long pieces, and drilled and tapped threaded holes for bolts. well, enough talk, heres the end result under the hood, ill take some pics of how they are on the two g31's in the back tomorrow or one day this week.
before...
pieces cut...
drilled and tapped...
hella grounded, one to the chassis and doubled to the engine block(also have double from engine block to frame not pictured)
end result...
well, thats all for now. comments, suggestions, anything appreciated.
//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
edit: and I'm diggin the bungee cord.
haha,thanks. try getting a g31 under the hood of a 02 grand cherokee and see how it works out //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Why the bus bars over what you had, did it not work? Why not just get some good battery terminals, the military type that will hold 5-6 crimp rings?
yea, it worked, but 500 watts work too, why do i have 5000? and i have g31 optimas, they dont have terminals, thet have 3/8" studs, and yes im aware they sell an adapter, but i had this idea and wanted to do it so i did
Two things....
1) Insulate that positive one... Please... Just some electrical tape....
2) Make sure that the length isn't going to act like a wrench on that bolt and unscrew it from the weight of the cables.... This could be very bad, especially if you don't do number 1...
Other than that looks cool...
Also, you put your highest current devices in the center right... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
That's what I like to hear //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
How much did that cost you, and where's your insulation for the terminals?
it didnt cost much. i got the aluminum for 15$ delivered to my door, then i think 7 for the drill bit and tap, and a couple dollars in bolts and a saws-all blade, so at most 25$.
jeepintn
jeepintn
Greenbrier, TN
05AztecRed
