My ****** is ROYALLY messing up, dunno if I can get to work. P0774
As of yesterday, my car started acting up. Its an 02 Qx4 2wd auto.
I already had code P0335 (crank position sensor) and I had just removed/cleaned it and orderred that sensor locally. But yesterday, I noticed my car wasnt shifting properly, on regular aceleration the car will shift into second smooth, but as soon as it goes to shift into 3rd..... ****** slips like a motha, revs up like crazy, sometimes shifts, sometimes the rpms just stay @ around 3k and that becomes its cruising rpm.... its like no power is getting to the ******/wheels.
When cruusing maintaining the speed limit, it stays @ 3k and when you push the gas the rpms rise but the car BARELY accelerates.
I checked the ****** fluid level in the dark, and it seemed fine, but Ill confirm in the morning when its cold and on level surface.
So I put the scanner on it. P0774 Shift Solenoid E Intermittent
I have the FSM, but cannot find it anywhere in the **** thing. Can anyone point it out to me. Basically I have no idea whats going on here, and I think I may have to borrow my parents car to get to work tomorrow since I work 40 minutes away and give them cab money since there local....
I made a video of the problem and its uploading onto you tube right now, shows the problem much better than I can explain. heres the youtube vid, processing or some bs, Ill try imageshack
http://www.youtube.com/watch?v=3kTOMtans1I
Any help appreciated
Well it threw a code P0774 Shift Solenoid E Intermittent
But I have no idea in english what the means, if its a simple fix, or if I need a load lol
And yes, car in my sig
btw, when in the vid I say Im sticking it into overdrive and say it does nothing, thats just my foot moving the throttle, overdrive usually make the car downshift... but obviously, it did not
I dont know a freaking thing about auto trannies so I couldnt tell you, I dont know if i need a new transmission at this point, or a simple solenoid, and if that part s inside or outside the transmission lol
Was hoping someone would know based off the code I pulled, which i have never heard of before
the part is a small solenoid similar to what they use as a battery relay on car audio stuff but much smaller, it is inside the ****** connected to the valve body get it fixed asap before it burns up the clutches. and you should probably take it to a shop.
WOT
Banned
WOT
Toronto,CANADA
WOT
