My head unit remote out line only puts out 5V?
akoakoako
All,
I am trying to troubleshoot why is it my amp is not working. Here are what I did so far:
1) I used multimeter to measure the voltage between the amp ground and positive when the head unit is off. I get roughly 12V - Good
2) I used multimeter to measure the voltage between the amp ground and positive when the head unit is on. I get roughly 5V - Bad
3)I used multimeter to measure the voltage between the amp ground and the power remote cable when the head unit is on. I get roughly 5V - Bad
My question is: why is it my head unit remote cable only puts out 5V? Also, why is it the voltage between the ground and the positive on the amp drop to 5V when the head unit is on? Please help me to shed some light..
My head unit is Nakamichi CD400. My amp is Orion 7005. I tried to switch the amp, and it also do not turn on. I am assuming this is a problem with the head unit.
Thanks!!
i am sorry guys, I measure the voltage incorrectly. The remote cable actually gives out roughly 12V too.
I do not understand, why is it my amp doesnot turn on. I already try it with 2 different amps, and both of them doesn't turn on. One of the amp is brand new.
Guys, this is what I did.
1) I measure the power cable and ground with the head unit turned off- 12 V good
2) I measure the remote cable and ground with head unit turned on and I didn't connecting it to the amp - 12 V good
3) I measure the power cable and ground with the head unit turned on- 3 V bad
4) I connect the power cable to the remote terminal - 3V too
my question is, why is it doing this? I can understand why is it the amp doesn't turn on since there is only 3V going in to the amp. But why is it doing this?
The funny thing is, at one point my setup was fine and then when I was driving all sudden it clip and shuts off.
I did the above steps with a brand new amps, and it exhibit the same behavior (voltage wise)
akoakoako
akoakoako
seattle
akoakoako
