MY CVRs Aren't Loud Enough!
I had a similar problem with my 10" cvx subs
Replacing your factory set will do some good. (I just don't know how much)
I put component sets in the front and 6x9s in the rear and powered those with a 4 channel, but simply replacing the speakers will help your overall sound.
It's not that expensive, and it WILL help either way. You will be able to turn your HU volume higher without distorting. After that if your CVRs aren't loud enough then you know exactly what to do.
I have a JVC HU that goes up to 49 and I've never need to go past 24 on it.
set it to 100-125, keep your bass, mids, and highs at o (flat)
Its something to do with your settings.
You really need a custom ported box.
So set the hpf to 100-125ish? Does the hpf affect bass coming out of sub?
what alpine hu are you using? it may have 2 volt preouts. 4 volt will also help with this problem. and keep the crossovers set for front and rear at about 125 with a slope of 18 db/oct. it's a steep slope that will really keep a lot of bass out of the stock speakers and will help a lot with distortion. in my truck i left the rear speakers stock and did exactly that with my alpine hu settings (cda-9855). i can get the hu up to about 17 or 18, which is where the internal amp on alpines tends to start clipping with the crossovers set. also, do what was previously stated, have the amp output the rated 750 rms at about 17 or 18 on the hu. also, although the subs are rated at 400 rms each for a total of 800 rms, you're putting them in a ported box. they will handle less power in a ported box. 300 rms each, look at the manual. now this is going to depend on the size of the box, however, using a prefab box, i wouldn't go more than probably 300 into them. also, make sure you are using the subsonic filter on the kicker amp. i'm not sure if this is even defeatable. the manual says it's fixed at 25hz with a 24db/oct slope. with a ported box and the power you're trying to put into these subs, if you don't use that, you're going to blow them. powered properly and tuned properly, they'll sound pretty decent. also, kicker has a prefab box that works well with these subs. it's tuned to 40hz i want to say. that would be decently loud. you should have went that route because they're prewired and you somehow turned a 4 ohm load to 2 ohms with dual voice coils (so you think). this could also be your problem. guess i could have misunderstood that one though. did you have a set of single 2 ohm subs wired into 4 or a set of dual 4's wired into 4? or did you somehow maraculously change the impedence of the coils?
get a line driver. also, if the problems is your the stock mids distorting at high volumes, replace those.
line driver will strengthen the signal running to your amp from the HU, so it will play louder will the gains lower, so you don't need to crank the whole system and ruin the SQ from the stock mids to get decent bass.
Fade to the rear a little maybe if you don't have rear speakers?
If you only go to volume 24 out of 49 on that jvc, your gain is probably set too high
Agreed it is.
Its on about 2/5 and I hate it (its more of a true 35) The HU threw it off.
I'm just not into constant super loudness anymore, but I do like feeling the bass from time to time
That's why I'm changing my setup.
I'm never going over 1000 watts again...
yes my alpine 9884 has 2v preout. i set the hpf to 125. should I go higher to 160?
Jer510
Slap Addict
Jer510
Oakland, CA
jpexpc
