63mopar
I am in between boxes thought I put up a couple of pics before they go back in the car.
looks like a decent subFor the correct fun in the low clay/tone cellar provides the new SIGNUM Subwoofer, which does not only impress by noble styling and substantial building method. In the „Herz“ the Subwoofer work 56 mm long wound 3“ (76 mm) of double moving coils on high-duty aluminum carriers, which Casting basket Casting basket-Boliden to linear, heavy up to 17 kg, +/- 20 mm stroke and high SPL propel.
Under the magnet hoods manufactured from aluminum casting 180 ounces work heavy double magnets, which convert the technical happening with high absorption and control as engines into impulse-faithful acoustic bass rendition.
So that the bass-enormous sound becomes usable without distortions also, to have the ESX technical designers for the use of torsionally stiff aluminum diaphragms decided, which guarantee high long-term quality in the fatigue strength enterprise besides in connection with the Santroprene Gummisicken and the in-woven braids.
Are available with up to the 1500 Watt peak loadable technical masterpieces as 12“ (30 cm) and 15“ (38 cm) versions in 2 + 2 ohms as well as 4 + 4 ohms of impedances, which can be begun in the parallel operation as 1 ohm or 2 ohms of Subwoofer and as idelae play partners for efficient Amplifiers to thus offer itself.
FEATURE
• 25 mm of Santoprene rubber Breitsicke
• Aluminum diaphragm with intensified structure
• Large silver Push pin terminals
• Punched polplatte with Logo and type of series
• Cooling openings for moving coil
• More high-efficiently 180 oz ferrite double magnet
• Aluminum casting basket in the dia. moon CUT Design
• Poly Cotton Spider also in-woven braids
• 3” (76 mm) of moving coil on aluminum carriers
SX 1222
12” (30 cm) Subwoofer,
750 Watts of RMS, 1500 Watts peak
Laid out for 2 + 2 ohms of impedance
180 oz. Ferrite double magnet
Xmax +/- 20 mm
Telex 29 cycles per second, Qts 0.41, VAS 37 L, 95 railways
Installation orifice: 280 mm
Depth: 168 mm
UVP/EUR 249.00
SX 1224
Laid out for 4 + 4 ohms of impedance
Xmax +/- 20 mm
Telex 30 cycles per second, Qts 0.47, VAS 37 L, 95 railways
Depth: 168 mm
UVP/EUR 249.00
SX 1522
15” (38 cm) Subwoofer,
Xmax +/- 20 mm
Telex 25 cycles per second, Qts 0.47, VAS 102 L, 97 railways
Installation orifice: 350 mm
Depth: 220 mm
UVP/EUR 299.00
SX 1524
Xmax +/- 20 mm
Telex 26 cycles per second, Qts 0,46,VAS 102 L, 97 railways
Depth: 220 mm
UVP/EUR 299.00
