my amp wont get a signal
Where is it grounded too?? I had a similar problem it was grounded to the side wall of the trunk. Once i grounded it to a different spot it worked fine so try grounding it to the floor if possible. Also Check the remote wire.
Good luck and let me know how it goes
Remote wire is a 12V lead connected to your head unit. It just tells the amp when to turn on and when to shut off. It's usually blue. Make sure that is tight. also check your fuses on the amp and under the hood.
it might. They should be in there nice and snug. What kind of amp do you have? Are the wires frayed at the amp or the fuse or both? If it's the amp you might wanna go out and buy forks. You just attach them to the wire and they hook onto the amp really nice. Alot easier then playing with the actual wires. Doesn't hurt to cut a bit off and put the wire back on. It'll make it look better at least. So all the fuses are fine and the remote wire is fine??
PimPnSk8r
PimPnSk8r
winston salem, NC
Jacobs
