my 200 amp alternator gets hot fast?
rasta4life
My 200 amp stinger alternator gets hot very fast,to make a long story short I had problems with my alternator and sent it to stinger and the problem was I had a sre bearing fail so they fixed it so they sent it back and I installed in my car.
I went to drive it and I drove it for about two miles I checked the alternator and it was hot as hell I do know what the heck is going on. Can somebody give advice what the problem my be thanks.
Umm...I'm not no expert but shouldn't it be hot. I mean engines only run at 200 degrees.
the alt should not get hot in 2 miles //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Edit: from a "cold" engine.
it supposed to get hot but not so hot where you cannot even touch it,yes it is bolted to the engine.I drive it for just say for five miles and **** it is freakin hot.
Thanks to those that are trying to help I apperciate the input. Anymore suggestions will help.
i say bushings, or reg.
I was just joking with the first post, but what is your voltage reading ?
thanks for the inputs but some are saying that my rectifier might be the problem.
your rectifier? does that go in your rectum?//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
rasta4life
rasta4life
New Mexico
BASSMEKANIK
