multiple runs of power and ground?
ryanrj828
Hello all,
Ill be running a skar 4500.1 at 1 ohm and im curious about how to run multiple runs of wire. Obviously the first power wire is run from the front battery fused twice in between. But for the second wire do I also run it from the front battery, or straight from the alternator to the back battery bank? Also for running 2 grounds how do i go about this? Never had a build of this power, usually i just ground it in the trunk.
Thank You
Hello all,
Thank You
My rule of thumb, for every power wire ran from front battery bank to bank battery bank match them with a ground from front bank to back bank. then wire from the back bank to the amp, and make a few grounds from the back bank to the vehicle.
ryanrj828
ryanrj828
michigan
bgowdy
