Buick_66
So in my build, I will have a bank of 6 batteries in my trunk, and a seventh under the hood, all dedicated to stereo only off separate alternator. I will still have my cars electrical system, and separate alternator working off the eighth battery in factory position.
So I'm planning on having busbars in the trunk to make things easier, which I will fabricate. I'm having all six batteries in the back connected by 2/0, from terminal to busbar, not battery to battery, and I'm running power and grounds up to the front for the seventh battery to connect to the same busbars.
I believe then I'm supposed to connect the negative busbars to chassis? And I've seen people running multiple leads from the busbar to the same grounding point on the chassis. Is this the right approach? And is the front battery ok and grounded (at the common point) or should I ground the front battery on chassis aswell? It's a big car, so about 15' o 2/0. I'm reading some things that say no, but I'm not sure if that's just in the case of amps? So all amps will be going through busbars aswell and grounded in the same spot...
I have 2 Hifonics XI Zeus amps, and the XI colossus running 1 Titanium Eclipse 15" Sub, 2 JL 8's, and 2 sets of 6.5 " focal components.
Just wanted to make sure I get it right. I've done lots of installs and builds, but this is getting up there for me.
Thanks, and go easy on us newbies. Some of us have some good questions I think!
