Multi amp setup question
rjay
I'm in the process of changing my system out. I will be running a singe IDMax 10" sub being ran by a JL Audio 500/1v2 amp and my front door components will be ran by a Boston Acoustics GT-275 amp (which puts out 75 watts x 2 ch). I will be getting the 4 gauge Knu Kolossus OFC amp kit and their fused distribution block. Both amps recommend 4 gauge wiring so I was planning on doing 4 ga in and out of the block if that will be okay? Then my other question is what size fuses would be best for this application? I believe the JL recommends atleast a 60a, if that's right? Then also what size would be best for the BA 2 channel amp? My car is a 09 Nissan Sentra with factory electrical and stock battery, if that makes a difference. Thanks for the help.
you might wanna do 8 gauge out. i don't recommend 4 gauge in and out, I don't think 4 gauge could support it for 2 amps. Either upgrade to 0 gauge for input and have two 4 gauges out, or get the 4 gauge kit and get oversized 8 gauge for outputs. Your amps aren't massive, so just having 4 gauge in and 8 gauge out should be more than adequate. Just make sure it's fused accordingly.
4ga in,and dual 4ga out never opposed an issue for one of my vehicles for over 5 yrs,with a 150a anl inline fuse, and both amps at the distro block fused 60 amps ea.under 1200 watts..no issues at all:)
If 4ga in and out would be okay then that would be nice, save me from ordering some 8 ga wiring! I believe the inline fuse is 120a so then a 60a fuse at the block, for both amps, would be good for my situation?
Id go min of 125a anl fuse at batt,and use required fusing for the amps,should be /work just fine.Do recommend getting the big 3 done as well
rjay
rjay
oklahoma city
audiobaun
