Yes. Take a DMM and turn it to DC voltage. Then stick the postive and negative in the positive and negative terminals on your amp channels. Turn you system up to what you usually listen to it at and play a test tone. I.E. download a 50 hz test tone on ROE and play it. Then record the voltage that it reads out. Take that voltage and square it. then divide it by the impedance and thats your wattage. For example, you turn the system on a 50 hz tone to the volume you listen to it at, you measure the voltage to be 20. You then square it so 20x20 equals 400. If you sub you have wired to the amp is wired to 2 ohms you take 400/2 so you amp is pushing 200 watts. The opposite of this is how your supposed to set your gains on your amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
