Sold MTX Thunder 4200X FS
2002XLT
Thats right bishes...
Not sure on specs, ill try and google in a minute. Amp is in good working condition, came out of my friends car about a week ago. Is a 4 channel but can be bridged. Only thing that will come with it is the amp itself.
90 Shipped OBO.
cant seem to find the factory specs on it, might be on the unit itself but dont have it in front of me, these are the only thing i found and im not sure if its correct or not.
Check below for full specs.
RMS Power measured at 12.5 Volts DC:
25 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
50 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
100 Watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
55 Watts x 4 into a 4 Ohm load
100 Watts x 4 into a 2 Ohm load
200 Watts bridged x 2 into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions:
11" x 9" x 2" (27.9cm x 22.8cm x 5cm)
12-1/4" x 9" x 2" (31.1cm x 22.8cm x 5cm) Including IsoFeet(TM)
I want it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif **** for no moneys.
2002XLT
2002XLT
H-Town, TX
2002XLT
BP1Fanatic
BP1Fanatic
