i heard the 1501d is the same amp diff case so it can be done...but how do you wire 3 15'' 4ohm subs on a modded 1501d it says in the manual do not wire 3 4ohm subs unmodded....so do i wire it the same way they tell you not to...2 4ohm subs on 1 channel and 1 4ohm sub on the other? does wiring it that way make a 1ohm load.....im confused.......and does a unmodded 1501d internally bridge 2 4ohm subs to make 2ohms....thanks for the help
can you wire 2 4 ohms subs wired in parallel@8ohms on 1 channel.... and 1 sub @4ohms on the other to make a 2.6ohm load....or just use 1 channel and wire 2 subs parallel and sreies the 3rd sub to make a 2.6ohm load........or does anyone know if the amp is stable to 1.33333 ohms unmodded....or if it were modded would it perform well at 1.33333 ohms @14.4v on 3 old 15''8000's....thanks for the help
