Sold Mtx 81000D f/s
below the only pic I have at the moment... I can take more upon request...
Im fairly new on here but if you check realmofexcursion.com im pretty well known and have a great reputation. My s/n on there is the same as here...
specs are,
Specifications
Power 12.5 VDC Input
2 Ohm Load 1000 w x 1 Low Level
4 Ohm Load 500 w x 1
Crossover(s)
Power 14.4 VDC Low Pass 40Hz-200Hz -
2 Ohm Load 1500 w x 1 Variable
4 Ohm Load 850 w x1 RCA Output
Low Pass Only
Dimensions
(with ISO Feet) Other Features
Compression Circuitry
17.8" x 9.75" x 2.1" Thunder EQ
45.2cm x 24.8cm x 5.3cm EBC2 Port
Rock solid amp, Never gets hot but then again never beat on... Comes with the remots bass knob too...
I got the same American Pro amp also, LOl POS. It not 1ohm Stable?
lol all the AP runs is a pair of 5 1/4s. The mtx is dot supposed to be 1 ohm stable but ive heard people run em daily at 1 ohm with no problems...
the mtx can be modded to run @1ohm same thing as the 1501d //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
your both correct. Ive heard from a few people that rms at 1 ohm is around 1750. Ive looked around on hoe to mod it and its simple as hell. just clip one thing out of the board. I just never wanted to try...
irupp33
irupp33
Florida
dr_spl
