Sold Mtx 81000D amp 4 sale.
playa2525
Item Specifics - Car Amplifiers
Brand: MTX RMS Wattage: 1500
Model: 81000D Condition: Used
Channels: Mono (1 Channel)
Hey i have mtx 81000D amp that will push out 1500rms at 14.4 volts at 2ohms. This is one of the loudest amp that i have heard. The amp works great. I will let the amp go for the first 275 bucks shipped for the amp. i just need the money. I have 2 of these amp.
On Jan-22-05 at 20:44:35 PST, seller added the following information:
The crossover is low pass, variable from 40Hz to 200Hz. And, we've even built in our compression circuit, to protect your woofers at high SPL levels. Add in the EBC2 and the Thunder EQ and this is one amp to be feared. Specifications Power 12.5 VDC Input 2 Ohm Load 1000 w x 1 Low Level 4 Ohm Load 500 w x 1 Crossover(s) Power 14.4 VDC Low Pass 40Hz-200Hz - 2 Ohm Load 1500 w x 1 Variable 4 Ohm Load 850 w x1 RCA Output Low Pass Only Dimensions (with ISO Feet) Other Features Compression Circuitry 17.8" x 9.75" x 2.1" Thunder EQ 45.2cm x 24.8cm x 5.3cm EBC2 Port Please let me know if you have any questions.
So how does that amp sound? Does it have alot of SPL or Sq? How many watts rms does that amp handle? What kind of numbers are you putting up with that amp since is so loud. What subs are you using to push the amp? How many watts are your subs giving your amp to make it loud?
playa2525
playa2525
frankfort,ky
playa2525
