mtx 6500d
i have a mtx 6500d and it says d technology what is that suposta mean. i bought it used. and i have 2 12 inch mtx 7500s dual 4 ohm. is this amp enough? suggestions on how to wire it all up? thanks
well first off, that amp puts out 500+ watts at 2 ohms. With the subs you have,both being dual 4 ohm, you can only wire them together for 1 ohm or 4 ohms. If you use just one sub you get the full power out of that amp 2 ohm. You need a different amp or you can put 250 watts to them in total. That amp is not a good match for your subs.
94 one ton
94 one ton
Farmington mi
t-money
